Signal Conditioning
Filter Validation with Step Response
I have some difficulties to validate the step responce of the casacded filter in labview. I have Moving avargae filter and Low pass filter in series and want to see the combine responce of both the filter as a step responce in time domain so please anybody has solution for this problem. If you can pst here then that would be great for all users.
The test singlas I need to test is from CRIO system or from external function generator.
I am looking forward for your answers/solution for the problem.
Thanks................
(5,429 Views)
Hello Ajaxy,
This seems to be a duplicate of this post:
http://forums.ni.com/t5/LabVIEW/Filter-Responce/m-p/2830858#M827565
Is this assumption correct?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(5,401 Views)
