Signal Conditioning
Ghost Voltage on Analgo Input Channel on SCU Board
Why am I seeing a ghost voltage on one channel on the SCBoard with nothing connected? I should be reading close to 0V from this channel with no connection.
A new signal conditioning board has been replaced.
(2,528 Views)
Input bias current?
Common voltage input circuits have a small current leaking out. Could be some fA up to some nA. Together with the input impedance ( R and C here) this results in measurable voltage at the input.
What do you measure with a 10M or 1M (or 50) resistor at the input?
Greetings from Germany
Henrik
LV since v3.1
(2,456 Views)
