Signal Conditioning
High strains measures
Hi!
I'd like to measure rubber strain with strain gauges. The strain can reach 15% of original lenght: 150,000 microstrains!
The NI 9237 has a nominal full-scale range of ± 25 mV/V, but with 15% of strain the voltage of the bridge could reach about 65mV/V.
I'm not a strain gauges expert, but i suppose that the bridge configuration is not suitable for this situations.
How can I measure this strains? I'm thinking to supply the gauge with a constant current and measure the voltage with a differential amplifier in 4-wire configuration.
Could it work? Are there some NI modules suitable for this kind of operations?
Thank you very much.
Domenico
Italy
(4,587 Views)
Hi Domenico,
I suggest to take a look to the following link that can help you to choose the correct modules and the appropriate conditioning for your strain acquisition:
Measuring Strain with Strain Gauges
I hope it helps! Best regards,
Marco
(4,572 Views)
