Signal Conditioning
How can I change the X-axis increment in a waveformgraph
The X-axis always increments by 1, but I am acquiring one point of data every 100 ms. So my chart moves 10 times fater that the real time. How can I set my x-axis to increment 0.1 every time I add data to my Waveformgraph in VB net?
The X-axis collection is not showing any property to change that.
I have a continuous data acquisition giving me timed data at 100 ms rate.
(4,491 Views)
Thank you for posting to the NI forums.  You can set the update increment of the WaveformGraph plot function by using the overloaded function as follows:
PlotYAppendMultiple( ByVal yData As Double(,),
   ByVal orientation As DataOrientation,
   ByVal increment As Double )
I did this in the VB.NET example program, "ContAcqVoltageSamples_IntClk", by adding the following line to the dataToDataTable function.
WaveformGraph1.PlotYAppendMultiple(sourceArray, NationalInstruments.UI.DataOrientation.DataInRows, 0.1)
The increment will be set to 1 / (sampling frequency), so in your case, it will be set to 0.1.  This function is documented in the NI-DAQmx .NET Framework 2.0 Help.
I hope this helps.  Post back if you have any further questions.
Ed W.
Message Edited by Ed W on 05-04-2007 10:36 AM
(4,478 Views)
