Signal Conditioning
How can I change the x axis to something other than time?
I've searched and couldn't find an answer to this. I need to plot load vs cycle count, and I cannot figure out how to change the x-axis from time to cycle count. In other words, I want to read the load on the y axis, and I want the plot updated everytime a cycle occurs.
(6,709 Views)
tavwtby,
You can change the name of the scale on the x-axis in the Scales tab of the Chart Properties Dialog Box (Right Click » Properties).  To have a plot update each time it recieves a new value, use a Waveform Chart (Controls » Graphs » Waveform Chart).  You can also change the Update Mode from Right-Click » Advanced » Update Mode.  See this link for more details:
http://zone.ni.com/reference/en-XX/help/371361G-01/lvprop/wfmchrt_updt_mode/
Drew T.
Camber Ridge, LLC.
(6,699 Views)
1). When I want counts vs. amplitude, I think "Histogram". Investigate the Histogram PtByPt.vi. See below for a graph example.
2). You're in the wrong forum, belongs in LabVIEW. Smiley Wink
Richard
(6,695 Views)
PtByPt.vi s for plot discrete data in histogram graph.. i want to plot continuous data (x-axis being voltage) and y-axis being counts
Krithika
(6,549 Views)
Kriti,
Have you looked at something like this:
https://decibel.ni.com/content/docs/DOC-4152
Drew T.
Camber Ridge, LLC.
(6,536 Views)
