Signal Conditioning
How can I configure SCXI-1180 to SCXI-1000 chassis
Labview does not autodetect SCXI-1180 module, how should I configure this module adjacent to a SCXI-1102 module?
(4,012 Views)
Hi Aliko
The SCXI-1180 is not a module but a feedthrough panel. Because it's not a module it will not be detected in MAX. It's slot appears to be empty. That's OK!
Luca P.
Luca
(4,012 Views)
Some additional Info:
The SCXI-1180 is not "intelligent". It's "only" used to access the unused channels on the DAQ device from the front of the SCXI chassis.
Luca P.
Luca
(4,012 Views)
(4,012 Views)
Hello;
The 1180 is a feedthrough module only, meaning that you can have access to the unsused channels and counters of the DAQ device that is connected to the chassis.
You don't need to configure that module.
Regards
Filipe A.
(4,012 Views)
