Signal Conditioning
How can I make sure the relays are off on a 1324 module when it powers up.
We have an application using the SCXI 1324 module. When the module losses power the relays keep their state. The control program attempts to set all the relays off when it starts up, but the 1324 assumes the relays are off when it powers up and the CVI call to turn the relay off does nothing until I cycle the relay on and back off again.
(3,961 Views)
OK, the 1324 is a terminal block. The relays in question are in the SCXI-1160 module.
(3,961 Views)
