Signal Conditioning
How do I connect a futek LRF325 load cell to an scc-68 terminal block
Hi slashc,
The scaling I mentioned is different than the custom scaling in your DAQ Assistant and therefore, this scaling is always being applied whenever a custom voltage with excitation is being measured. Also you should make sure to set the proper range for your task. Please keep us posted on your progress.
S_Hong
Message 11 of 11
(3,140 Views)
