Signal Conditioning
How do I get a list of configured channel using DAQmx
I would like to know how to read the channels in a task list or the global channels that are setup in MAX. I use to be able to do it in DAQ using the read channel VI. I can't find any equivalent in DAQmx. My new system works only with DAQmx. My program allows the operator to select from the channels configured in MAX.
(3,422 Views)
Hi Benegin,
This can be found under the DAQmx System property node. I have attatched a picture to help you find it.
-Sal
(3,410 Views)
Sal,
Thank you for your reply. It is exactly what I was looking for. Thanks for sending the path to it. It was buried quite deep.
Howard
(3,396 Views)
