Signal Conditioning
How do I paste a "print screen" picture into a message?
(5,978 Views)
Hi Nicholas,
To post a picture on our threads you can either attach the image or use a url to a picture.  If you already have the url to the image you want to post, please just look at the image below on how to link that image on the post.  If you need to attach the image to the thread first, you will need to post first and then, after posting, right-click on the image and select copy link location to get the link to where the image is stored.  Then you need to edit your post by going to Options » Edit Message and add the image by using the image button.  This is shown below.
In addition, did you post on the Signal Conditioning board because you had a question regarding signal conditioning?
Message Edited by Paul C. on 10-15-2007 10:05 AM
(5,967 Views)
I just wanted to know if i did it right. That is pasteing the picture. Are you able to see it?
(5,959 Views)
Guess you did not do it right
(5,949 Views)
