Signal Conditioning
How do I switch between RS-422 and TTL signals?
Hello all,
I need a circuit to switch between 2 pulse signals and the input the same for both (one is TTL and the other RS-422).
Is there any IC that could execute this?
Thanks in advance
Kelson
(6,976 Views)
I guess you need more than one IC to SWITCH. TTL is voltage driven, RS-442 is current loop.
Or do you need a driver circuit from one to the other?
Appnotes from National Semi, Linear, Maxim will help 😉
Greetings from Germany
Henrik
LV since v3.1
(6,948 Views)
This can be done with a analogue switch like a 4066 but it depends on your circuits and want you want to do.
(6,942 Views)
