Signal Conditioning
How do i hook up a Plug-In Relay to thermocouple?
These are some details about a fan I am planning on using.
Specifications
Manufacturer: Suncourt
Manufacturer Product No.: DB204
Duct Diameter: 4"
Unit Weight: 4.50 Lbs.
Max Boost CFM: 80
Free Air CFM:65
Amps: .30
Housing Length: 6"
dBA: 52
Blade Type: Polycarbonate
Motor: 110V, Class B, Thermally Protected (T.P.)
Message Edited by nicholas03 on 10-22-2007 04:38 PM
Message 11 of 12
(1,948 Views)
Based on the specifications that you posted for the fan I do not see anything wrong with using that fan The fan only draws .30A and your relay is able to supply up to 4A which should be more than enough to power this fan. Once again I am not familiar with this hardware and this advice is based purely on the MCC website for more detailed information on operation and connections MCC would be your best point of contact.  I hope this helps!
JaceD
Signal Sources Product Support Engineer
Message 12 of 12
(1,926 Views)
