Signal Conditioning
How do you setup a channell for a Lebow torque sensor using scxi 1121?
i am using a Lebow 1104-2k Torque transducer. I am connecting it to an SCXI 1121. I want to know how to configure a channel to read the torque. How do I do this?
(3,733 Views)
Hello;
You can do that is Measurement and Automation Explorer (the blue NI logo at your desktop screen). Then, you create a virtual channel, configure the channel as a voltage input, and enter the scalling for that particular sensor. You can probably get all the information as far as scalling from the sensor vendor.
After you enter those numbers, you should be all set to start your acquisition.
Hope this helps.
Filipe
(3,733 Views)
