Signal Conditioning
How does digital output work on 2345.
I am trying to use DO function to control a solenoid on a valve. I am new to Labview and Data aquisition, I managed to set up the program to read analogue inputs from 5 pressure transducers and displayed it as a graph, But i am confused as how I can include in the same program a codde that will use digital write to line or write to port to control at least 6 SCC-RLY01.
Please help
yemi
(4,564 Views)
Hi Yemi,
You should be able to just use another task to do the digital output. What problems are you running into? Are you using the DAQ assistant? Can you post an copy of your code?
Regards
Jon Bowers
NIUK
(4,551 Views)
Hi Jon,
Thanks for your response. How do I copy my doce into this forum, I selected the code and copied it, but it wont paste into this message editor
Yemi
(4,552 Views)
Hi Again Yemi,
When you are writing a post, just bellow the message body there should be a field marked Attachment. If you click on the browse button next to it and then browse to your vi you will be able to attach it to your post. If you have any sub-vi's that you have created in your vi the click ADD Additional Attachments to attach them aswell.
Regards
Jon B
NIUK
(4,546 Views)
Thanks Jon, find attached the code.
cheers
yemi
(4,545 Views)
Hi Yemi,
What are the exact problems you are having with your code. The vi that you posted seems to work fine for me.
Regards
Jon B
NIUK
(4,510 Views)
