Signal Conditioning
How i can read analog signal, use the values and save to column
I use SC-2345 and couple of SCI-CI20, I read values between start and stop, I also use values in my program.
How i can save the data to columns?
I have tried that with "AI Acquire waveform" block but it mixes the values.
1. 2. 3. <- channel
4.00 6.00 5.00 <- 1. value
4.01 6.05 4.06 <- 2. value
Reading rate is 1 KHz, i dont know how many sample i have... but max. is 65 000 -> 65 seconds
(3,053 Views)
Hello Jani,
So if I understand well, you are not having a problem with the actual acquisition of your data, but rather with saving the data in columns after acquisition. What do you mean by "it mixes the values"? In addition, how are you saving the data that you acquire and what would you like the saved data to look like?
Serges L.
(3,037 Views)
