Signal Conditioning
How to Simultaneously measuring strains with SCXI-1520 and voltage input in other channel in ONE DAQ card 6024E
I am using two multiplex mode of SCXI-1520 strain module. I want to take and stains and other voltage measurment at the same time by one 6024E card. I try to combine the two progames but it doesn't work. Pls help!
(3,176 Views)
Below is a knowledge base that discusses how to measure simple voltages with the SCXI-1520. It explains how you can configure individual channels to do so. Once you've done this, you can set up a simple acquisition where you read all of the channels at once (strain and voltage). The output of the AI Read.vi will be a two dimensional array where each column corresponds to one of your channels. Then you can simply scale and apply the strain conversion to the applicable channels and leave the other channels alone. I hope this information helps.
Knowledge Base
(3,175 Views)
