Signal Conditioning
How to detect as to which slot the SCXI module is present
i want to detect to which slot the scxi module is connected . I have used get scxi info vi , but the
disadvantage is that it does not give the exact slot position the module is present . Please let me know any vi which does this function
Suresh Thangappan
(3,143 Views)
Hello Suresh,
Thank you for contacting National Instruments.
If you have LabVIEW 7.0 or higher, you can use the DAQmx Device Property Node with our NI-DAQmx driver. I have attached an example VI to demonstrate just how easy this can be accomplished.
Bill B
(3,143 Views)
