Signal Conditioning
How to determine SCXI module type programmatically
I have an application which can use either SCXI 1300 or SCXI 1303. SCXI 1300 uses IC sensor and 1303 uses thermistor. Hence I would need what type of device is currently in use for proper temperature calculation. Assuming that only one type of SCXI is connected at a time, is there a way to do this from LabVIEW 7.1 programmatically? Is there any property node?
Priyadarsini S
Message 1 of 1
(6,336 Views)
