Signal Conditioning
How to filter
Hi
I am new to labview and I am trying to filter the noise from a file and so far I have managed to smooth the data up to this point, using Butterworth and linear fit then using Savitzky-Golay and median filter, but now I am stuck. Any help or suggestions with a better filter process would appreciated.
(2,751 Views)
Filtering is always relative. It is up to you to determine what is signal and what is noise.
We cannot tell by just looking at a random picture, but it almost looks like you are already overfiltering, i.e. there is a strong correlation between adjacent points. How did the unfiltered data look like? What is the data expected to look like? What is the purpose of filtering?
If you have a mathematical model for the expected functional shape you could try nonlinear fitting. No filtering needed. 😄
(2,735 Views)
