Signal Conditioning
How to generate an output signal ?
We are using SCXI 1000 chassis and SCXI 1125 module for data acquisition. Can we generate an output signal through this hardware?
(3,161 Views)
Greetings,
With this hardware alone you cannot output a signal. The SCXI-1125 only gives you access to the analog input lines of your NI-DAQ board.
I would suggest using an SCXI-1180 feedthrough module to access the analog output ports. Here is the overview of this panel from our website:
Overview
The SCXI-1180 feedthrough panel extends the I/O signals of the plug-in DAQ board to the front of the SCXI chassis. The SCXI-1180 is installed in a single slot of the SCXI chassis, and connects to the 50-pin male breakout connector of an SCXI cable assembly, such as an SCXI-1349 or SCXI-1353 connected to an SCXI module in an adjacent slot. Alternatively, if you wish to access I/O signals of additional DAQ boards, you can cable a separate DAQ board to the 50-pin rea
r connector of the SCXI-1180 with the appropriate cable.
Hope this helps,
Anuj D.
(3,161 Views)
