Signal Conditioning
How to get rid of the noise in sc-2040 results from the eletromagnetic noise from a wind tunnelmotor.
I am using a sc-2040 for two channel simultaneous measurement inside a wind tunnel test section. The wind tunnel motor generates electromagnetic noise that interfere with the signal from my sc-2040. Anybody knows how to fix this besides replacing the motor?
(3,220 Views)
Hello -
Are you using shielded cables and connector covers? If not, that will greatly help reduce noise.
How is the noise interfering? Is it possible for you to use a filter to remove the noise? You can either use hardware filters or LabVIEW to filter out noise frequencies.
Let me know if this information was useful or if you require more help. Have a great day!
Becky B.
Becky Linton
Field Engineer
Office: 734-464-2463
Cell: 248-709-2822
Email: becky.linton@ni.com
(3,220 Views)
