Signal Conditioning
How to wire to SCXI 1163R
If there are 3 wires -positive, negative and ground from a solenoid valve that need to connect to SCXI1326/SCXI1163R to be controlled by Labview, is that correct that the positive one should connect to CH, negative one connect to GND and ground wire connect to solder lug?
If I want to control 4 solenoid valves (on and off)at the same time, is that true that I connect all 4 positive wires to 4 channels respectively in one bank, all negative wires to GND and all ground wires to solder lug?
Thanks for help.
(3,553 Views)
Hau,
Figure 3-2 on page 3-4 of the SCXI-1163R User Manual (link available below) illustrates the relays provided by this module.
You will want to use these relays to connect/disconnect your power source from the solenoid valves. What type of power source do these valves require? The exact connections you will need to make to the SCXI-1163R are dependent upon this power source.
Good luck with your application.
Spencer S.
(3,553 Views)
Thanks for help.
(3,553 Views)
