05-10-2011 01:31 PM
Like the title says, I get an error every time I start my program unless I cycle the power on the SCXI chassis.
This is the error:
08:31:21 ResetDevices
NationalInstruments.DAQmx.DaqException: Module specified in the hardware configuration is not the module found.
Make sure that the module specified in the hardware configuration is present in the specified slot.
Device Specified: SC1Mod1
Status Code: -200107
at nNIMSSAIL100.StatusObserverT<nNIMSSAIL100::ApiTraits<nNIMSSAIL100::DotNetApi> >.CheckWithName(StatusObserverT<nNIMSSAIL100::ApiTraits<nNIMSSAIL100::DotNetApi> >* , tCaseInsensitiveBasicString<unsigned short\,_STL::char_traits<unsigned short>\,_STL::allocator<unsigned short>\,nNIDMXS100::tLocaleConsideringWideStringComparitor\,nNIDMXS100::tLocaleConsideringWideStringCaseForcer>* pName)
at NationalInstruments.DAQmx.Device.Reset()
at DEER_DAQ.modFunctions.ResetDevices()
This is my reset procedure:
Public Sub ResetDevices()
Dim devices() As String = DaqSystem.Local.Devices
Dim tempstring As String = ""
'Array.Sort(devices)
Try
For Each tempstring In devices
If Not tempstring.Contains("cDAQ") Then
dvc = DaqSystem.Local.LoadDevice(tempstring)
dvc.Reset()
frmD.txtMessage.AppendText(vbNewLine & dvc.ToString & " reset.")
End If
Catch ex As Exception
swError.WriteLine(TimeString & vbTab & "ResetDevices" & vbNewLine & ex.ToString & vbNewLine & vbNewLine)
Select Case MsgBox("Could not reset " & tempstring & ". Are you using this device for the current channel configuration?", MsgBoxStyle.YesNoCancel, "Error Resetting Devices")
Case MsgBoxResult.Yes
If MsgBox("Please ensure that the SXCI chassis is turned on. Possible reasons for failure " & _
"include a blown fuse, being switched off, a bad power supply or being unplugged. " & _
"Press OK when SCXI chassis is powered on or cancel to quit.", MsgBoxStyle.OkCancel, _
"Warning!") = MsgBoxResult.Ok Then
ResetDevices()
Else
End
End If
Case MsgBoxResult.No
Exit Sub
Case MsgBoxResult.Cancel
End
End Select
End Try
End Sub
Any ideas?
05-11-2011 05:01 PM
Hi Michael,
What happends in Windows Device Manager and Measurement and Automation Explorer when your program cannot find your SCXI? Can you check to see if NI Device Loader is starting automatically in Windows Services?
Windows 7:
Control Panel » Adminstrative Tools » Services
05-27-2011 08:26 AM
I can't communicate with the device in MAX when this problem occurs. I will have to check on the device loader.
