Signal Conditioning
I am using an NI Data Acquisition board (PCI-6023E) with LabView taking inputs from temperature sensors (+5v VCC and 5V Vo) and airflow sensors (+12V VCC and 5V Vo). Can I mesaure both sensor outputs with respect to the same ground i.e. the DAS ground ?
e: I am using an NI Data Acquisition board (PCI-6023E) with LabView taking inputs from temperature sensors (+5v VCC and 5V Vo) and airflow sensors (+12V VCC and 5V Vo). Can I mesaure both sensor outputs with respect to the same ground i.e. the DAS ground ?Yes. You can reference all signals to AIGND for RSE mode, or AISENSE for NRSE mode.
(5,167 Views)
