Signal Conditioning
I safely convert the 24 V PWM output from the NI-9474 into a clean 0–5 V PWM signal
How can I safely convert the 24 V PWM output from the NI-9474 into a clean 0–5 V PWM signal that:
Drops below 0.97 V when LOW (to turn the pump ON),
Stays near 5 V when HIGH (to turn the pump OFF),
And follows the duty cycle accurately?
transistor circuit, optocoupler, or logic-level shifter—whatever works best with the NI-9474's sourcing output.
(307 Views)
You can change the power supply connected to 9474 to be 5V and you don't need an external logic level shifter.
If you can, I would recommend buying another DO card for the 5V signals instead of having to purchase external signal level shifter and wiring.
Santhosh
Soliton Technologies
(265 Views)
