Signal Conditioning
Inaccurate Impact Reading from ICP Force Sensor
I am very new to LabView and have inherited an SCXI-1001 chassis with an 1303 module connected to an 1102. I am trying to run an ICP Force Sensor from PCB through their signal conditioner to a simple Analog Input Voltage on the DAQ Assistant. It seems to behave properly with slower inputs (such as pressing on the sensor with a thumb), however, any sort of fast impulse is extremely inaccurate (whacking the sensor with a hammer produces the equivalent of a 5-8lb force). We have tried changing our sampling rate to no avail. Most of the tutorials/examples I have seen online seem overly complicated for what we are trying to do, but perhaps I am just too inexperienced with LabView.
I will try to supply as much documentation as I can.
Sensor:
https://www.pcb.com/contentstore/MktgContent/LinkedDocuments/Force-Torque/TM-FRC-208C_Lowres.pdf
Signal Conditioner:
https://www.pcb.com/contentStore/docs/pcb_corporate/electronics/products/specsheets/480c02_p.pdf
I attached a picture of my setup for the Analog Input Voltage, the smooth rise is from my thumb and registered around 18lbs (1mV = 1lb) and the small sharp peak is from a firm strike with a hammer (only registering at  5lbs).
Any thoughts as to why this may be happening would be greatly appreciated.
Message 1 of 1
(1,149 Views)
