Signal Conditioning
Interfacing ScXI 1121 with SCXI 1320 and SCXI 1000
New here and want to share my problem before accidently spoiling any device !!!
I am using a system having SCXI 1121 with SCXI 1000DC and SCXI 1321,its working fine.But I need the same SCXI card From this system to build another system having SCXI 1121 interfaced with SCXI 1320 and in SCXI 1000 chasis.My question Can I use 1121 with 1320 and 1000?Would it cause any problem, if any kindly share? Would it be compatible and will not cause damage to any of the above components?Smiley Sad
(5,637 Views)
Hi waqas10N,
The 1121 module should be compatible with the 1320 terminal block and SCXI 1000 chassis. In fact, the manual for the SCXI 1121 specifically mentions using these pieces of hardware in conjunction with one another. Hopefully this helps!
Best Regards,
Thomas B.
(5,622 Views)
