Signal Conditioning
Is the USB-6251 compatible with the SCXI-1000 and SCXI 1531
I have a USB-6251 M-Series A/D board that I would like to use with my SCI-1000 chasis and SCXI-1531 8-channel accelerometer board.   I can't seem to get these to work together in Measurement & AUtomation Explorer.  Can these boards be used together?
(6,269 Views)
Hi MTU,
It looks like if you use the proper version of DAQmx (later than 8.9) and have the mass termination model you should be in the clear according to this KnowledgeBase.
Dustin D
(6,255 Views)
