Signal Conditioning
Is the connection of thermocouple need any signal conditioner if we use a NI USB-6216 Card?
I have a NI USB-6216 Card and I want to use it to measure a temperature using a thermocouple but I want to know if I need a signal conditioner circuit in this case
Best regards
(7,002 Views)
Hi kukarobot,
Themocouples do typically require signal conditioning becuase they have such a small signal and are succeptable to noise because they are antennas.  A low signal input range (minimum for 6216 is -200 to +200 mV) helps to get better resolution with the thermocouple, and a lotpass filter can help to knock off the noise on the line.  This can be done in LabVIEW with a filter.
Also, you can opt for a low-cost TC01 for a single TC or multiple or USB 9211 or 9213 for multiple thermocouples.  The devices have lower input ranges and the filtering built in.
Best,
Adam
Academic Product Manager
National Intruments
(6,986 Views)
Dear Baker
Thank you for your reply. I use a K-type thermocouple in this project which has a voltage range (-6.548---54.874 mV) and I think that the range -200mV to 200 mV. In my case I must to use a NI USB-6216 Card so if you can suggest to me an electronic interface circuit to make amplification for thermocouple (mv)
Best regards
(6,964 Views)
Hi xenon,
I did a quick search at sparkfun.com for "amp" and this was a result.
http://www.sparkfun.com/commerce/product_info.php?products_id=306
Hope this helps.  I recommend using a module that already had the cirucitry built in as suggested above, but this is an option that might work.
Best,
Adam
National Intruments
(6,943 Views)
