Signal Conditioning
Is there any way to use an SCXI-1321 front module with an SCXI-1122 board?
I have an SCXI-1122 board and an SCXI-1321 front module. Is there any way to make the two work together. From what I can tell, I need an SCXI-1322 to work properly with the 1122.
(3,139 Views)
The SCXI-1321 terminal block was built for use with the SCXI-1121 module. Since the input connectors for the SCXI-1122 and the SCXI-1121 are different, you won't be able to use the SCXI-1321 with the SCXI-1122.
So, you're right, you will need the SCXI-1322 terminal block with the SCXI-1122.
Let me know if you have any additional questions. Have a great day.
Todd D.
NI Applications Engineer
(3,139 Views)
