Signal Conditioning
Magnetic Pick up Analog AC frequency measurement for Turbine Flow meter
Hello!!
I am using the following hardware configuration to measure flow rate from a turbine flow meter.
Hardware: SCXI 1000 chassis
                  SCXI 1102 voltage input module
                  SCXI 1303 terminal connection block
Turbine Flow meter: output signal is ac frequency (30mv peak to peak). Sensor is magnetic pick up type.
I tried converting the output voltage signal to frequency domain using FFT but I am getting erroneous data.
I am wondering if anyone can suggest any good troubleshooting techniques so that I can figure out what is messing up my measurement or my measurement technique in labview itself is wrong completely?(From my understanding I believe I can measure the frequency of the ac voltage signal generated by the sensor by FFT. By measuring frequency I can calculate the flow rate)
I am aware that one potential cause might be ground loop in the system. The signal is grounded only in SCXI 1102 with factory default bias and pullup resistior network. I cannot think of any other reason for wrong readings or fault in my measurment. Also the flowmter is brand new and there is no chance of damage to the sensor.
I am sorry if I am missing out any important detail to answer as I am relatively new to data acquisition techniques.
Thank you
Regards
Aditya
(4,790 Views)
 Some typical data to look at would be helpful 🙂
The easy way to get the frequency is the 'extract single tone detection.vi' , capture about 15 periodes of the signal ..
BTW: What frequency range do you expect to see?  If the frequency is above the line frequency and say 5 times the harmonics -> ~ 300Hz , you can use a software filter (highpass) or just tell the tone detection vi where to look for the frequency.
One trick you can try to minimise the ground loop ac hum:
Don't use the internal bias resistor, instead, connect a 100k potentiometer (trimmer) between A+ and A- and the wiper to AGND. Now, while looking at the measured signal, you can search for a hum minimum setting at the trimmer.
Greetings from Germany
Henrik
LV since v3.1
(4,765 Views)
Thanks for your reply.
I realized the problem is because the DAQ system (SCXI 1102) has a minimum voltage requirement of 100mV and my flow meter generates a signal with 30mV peak to peak.
I was wondering if you have any suggestions on how to amplify the signal without altering the frequency of the signal. The frequency range is from 150Hz to 900Hz. This way I am thinking I can amplify the signal and then connect it to my DAQ.
I understand that this topic is not relevant to this forum but still I am hoping someone with good experience can guide me.
Thank you
Aditya
(4,753 Views)
Accepted by topic author Aditya_K
It's about signal conditioning .... and thats what you want to do , so it's not so far away 😉
And if your signal has about 30mV peak to peak it fits perfect into the 200mV peak to peak range...  I would say no need for amplification ... the +- 100mV is not a signal minimum, it's the signal maximum in that range 😉
Hook it up, take a measurement in single channel mode with the a samplerate of about 10kSPS take 100ms (1000points)  and feed it into single tone detection ..
display it with a signal graph , stop the vi, in the diagram rigth click on the graph icon and create a constant, save that in a vi and post it here if you need help in signal processing
Henrik
LV since v3.1
(4,748 Views)
Thank you for helping me through the problem and educating me.
Appreciate your effort.
Regards
Aditya
(4,647 Views)
