Signal Conditioning
Measuring higher than 300Vrms
Hi.
We're looking for possible solutions to measuring voltages higher than 300VAC rms (closer to 350VAC rms) using the 9225 cRIO module (or even one of the +/-10V analog modules).
Our application is fairly space constrained so traditional use of PTs/etc may not be suitable.
We also need the solution to have fairly decent frequency response to about 10kHz.  Would anyone have any off-the-shelf solutions or suggestions?
(6,020 Views)
If the 600 V channel to channel isolation of the NI 9225 is sufficient for your application, you might consider a 2:1 voltage divider in front of the NI 9225.  This would certainly be the simplest approach.  That would make the input range 600 V.  If necessary a voltage clamping device rated at 300 V could be added to protect the input module.
If you need more isolation, you will need to look at other techniques.
Lynn
(6,013 Views)
Hi Lynn.
We're really looking for a ready made/off the shelf solution to avoid any certification issues/etc.
(6,009 Views)
I cannot help there.  I am not familiar with what might be available with certification.
Lynn
(6,004 Views)
Maybe an interface module like the 2811103 MCR-VAC-UI-O-DC from Phoenix contact is a solution. Not the frequency response you want but it is a start.
There are more manufacturers that produce interface module like this one.
Kees
(5,995 Views)
