11-11-2008 05:34 AM
Hi all,
Is there any chance to read thermistors more than 10K ?
In particular I have to use 12 22K ohm thermistors.
Thank you in advance,
Pets
11-13-2008 09:01 AM
Hi Pets,
Unfortunately the maximum resistance the NI 9219 can measure is 10.5 KΩ. Other posts are related to the same issue. If you need to measure temperatures below 0°C you will still need external signal conditioning (such as a shunt resistor in parallel with the thermistor): see: thermistor data acquisition using cDAQ-9172 You can even measure the thermistor with a 9215 but using this module would require external excitation current and signal conditioning too.
Regarda
HUDSON
