Home
Community
Discussion Forums
Most Active Hardware Boards
Signal Conditioning
Topic
Signal Conditioning
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Need For Help With SCXI-1102 - Reading individuals Channels
Bush-Man
Member
03-09-2003
03:04 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Can I read individuals channels separated with commas, using SCXI-1102 ? If I read using this syntax "1:5", everything is O.K. I want to read channels 4,8,15,22 using the SCXI-1102 Labview example and I got -10007 Error Code.
what i'm doing wrong ?
0
Kudos
Message
1
of 3
(3,306 Views)
Reply
Re: Need For Help With SCXI-1102 - Reading individuals Channels
logman
Member
03-10-2003
12:43 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Here is a link which should explain this for you, but basically you must scan channels sequentially with the SCXI-1102.
Scanning Multiple, Non-sequential Channels from SCXI Modules
1
Kudo
Message
2
of 3
(3,306 Views)
Reply
Bush-Man
Member
Author
03-13-2003
01:56 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Thanks For your answer. It helps me a lot.
thanks again...
0
Kudos
Message
3
of 3
(3,306 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
