Signal Conditioning
Noisy Analogue Signals From SCB-68
I have a set up as shown below.
Futek Load Cells >> SCC-SG04>> SC-2345 >>SH68-68EP Cable >> SCB-68 >> Analogue input of PCI 7350 8 axis motion controller.
This set up has resulted in a noisy analogue signal from 7350 with high amplitude spike.
I had tried to check the signal from load cell by connecting load cells >> SCC-SG04 >> SC-2345 >> M-Series DAQ card, the reading was fairly smooth with no spikes. Therefore, i suspect the noise was picked up in the connections for SCB-68.
Is this set-up correct to connect the load cell signals to PCI-7350? If so, how can I reduce the noise picked up from the connections?
Thanks for helping.
Message 1 of 1
(6,249 Views)
