Signal Conditioning
Output Sweep
I have a small and simple problem. I want to sweep the signal using Keithley 2410 1100V SourceMeter. I setup everything properly. But then when I want to sweep the signal, the SourceMeter doesn't show anything until I press "sweep" button on the instrument. Can I make it trigger the sweep (and show it on the instrument and in Labview) when I start the process in LabView?
Thank you!
(4,617 Views)
Duplicate Post, see:
http://forums.ni.com/ni/board/message?board.id=140&message.id=24624
(4,612 Views)
