Signal Conditioning
PT100 Interface on myRIO
I need to interface two PT100  on myRIO 1900 in order to acquire two tempeartures.
In order to minimize the error due to the cablelength I woul perform a 4 wire connection, to do this Ineed to use a bride, but I don't understan hoe to connect the bridge to teh Aor B connectors of myRIO.
can someone help me?
regards
David
(4,137 Views)
Have a look at the
MAX31865
I think the myRIO has no dedicated resistor measurement good enough for a Pt100
You get boards for about  5$
Greetings from Germany
Henrik
LV since v3.1
(4,110 Views)
Hi Henrik,
thanks for your suggestion, I need also to acquire 2 resistance values(not RTD) but I need an extreme accuracy of measurements, so I would like to implement a 4 wire measurements do you have an idea about which one can be the best solution?
ciao
david
(4,103 Views)
@David15 wrote:
.. I need an extreme accuracy of measurements...
And what do you mean with 'extreme accuracy' ??
A colleague just go with a good ol' ASL F900  ... 😄
Spoiler
and that's only half the battle
(or a quarter??)
a good known(!) reference resistor,
a good known(!) SPRT
some ITS90 reference points (at least a triple point water cell)
Henrik
LV since v3.1
(4,096 Views)
I
need to read milli ohm.
ciao
David
(4,091 Views)
Oh, come on, what does it mean 'need to read milli ohm' ???
Please learn how to write and read metrological requirements 😉
If you need mOhm accuracy reading a 100 Ohm resistor (or Pt100) that is 10ppm .
Usually a job for a 8.5 digit meter and not a myRio 😄  see here
The trick is to use comparison techniques ...  like a bridge
Henrik
LV since v3.1
(4,087 Views)
