Signal Conditioning
PXI 4464 noise floor instability
Hi all,
I'm facing some issue with PXI-4464 used as acquisition card. I'm providing an input signal 1Vp@1kHz and measuring the FFT spectrum using the DSA Soft Panel. The input signal is provided by PXI-4463, but the issue is the same if I use an external waveform generator, so it is not related to the source. The issue is that the spectrum noise floor is not repeatible, that is if I launch the acquisition let's say 10 times, I get  nearly 7 times a "high" noise floor and 3 times a "low" noise floor. Also strange the fact that when the noise is lower at low frequency, it is higher at high frequency and viceversa. I have tried to change the input termination, the input range, the sampling frequency, no way. See attached plots. Another information: it happens only if I stop and restart a new acquisition, while if I continue with the same run the floor tends to be constant.
Looks like some memory or DSP circuit is not well resetted. Any clues?
Thanks in advance.
Federico
(1,447 Views)
It could as well be a bug in the DSA soft front panel. I would recommend performing the same experiment using the DAQmx drivers.
Stop and restart the acquisition would reset some circuits on-board, that could as well be the case.
Santhosh
Soliton Technologies
(1,443 Views)
