Signal Conditioning
PXI-6704 Analog Output Card Increasing Current Sourcing on Voltage
I want to run 0-10V across a resistor network of 20ohms, because I want to stimulate the voltage sensing on the terminals.  The PXI-6704 is rated as +/- 10mA.  How would I be able to increase the current sourcing to 500mA?  Can I place a bench power supply in parallel with the PXI card?
(2,340 Views)
You need an amplifier/buffer.
Some bench power supplys have a control voltage input....  however you can use it to supply a power OP ...
https://www.analog.com/media/en/technical-documentation/data-sheets/1970fe.pdf
is just one that pops up
BAD BAD idea ...  No
Greetings from Germany
Henrik
LV since v3.1
(2,310 Views)
