Signal Conditioning
Phase difference
I'd like to plot phase difference between two signal(input-output), the method which I'm using currently, is taking "FFT" and (r-teta)....and subtracting the phases, but what I obtain isn't so desirable, Do you know anyother option or suggestion to make my results better?
I've attached the plot and marked them, one of the is "Output FFT- magnitiude vs. Frequency" as you see it's acceptable, but another which is "phase difference vs. freq" isn't so good.:(
Petar
Message 1 of 11
(7,932 Views)
This does not seem to be a Signal Conditioning issue. You would probably get more responses if you post in the LabVIEW Board.
We really cannot see the scales on the plots and, more importantly, we cannot see the actual data. Please save some typical data as default values and post your VI.
If either the input or output signal is very noisy, it may be difficult to define or measure a phase difference.
Lynn
Message 2 of 11
(7,926 Views)
Some code and data really would be helpful......
Take a look at the FRF examples.....
two points:
use a phaseunwrap after calculating the difference AND
include a basic groupdelay for your (response) signal either in the time or frequency domain....
Greetings from Germany
Henrik
LV since v3.1
Message 3 of 11
(7,894 Views)
As they said if you provide more information maybe we will be able to help you
Randy @Rscd27@
Message 4 of 11
(7,883 Views)
Thanks for your replies, I've attached the acquired data..
(notepad file).1 column: Frequency......2nd column (FRF of output- magnitude)...........3rd column(FRF phase difference(output-input)).
In the figure: left column: input....FRF magnitude.................right column: output...phase frf....fft of output in every step.
thanks
Petar
Message 5 of 11
(7,877 Views)
Can you gives the whole project. It says i have some SubVIs missing.
Randy @Rscd27@
Message 6 of 11
(7,862 Views)
Accepted by topic author Petar2015
here is a short play around with  phase unwrap a groupdelay of >1s ????
What and how are you measuring????
Can't open your code... still stick to an old version here
Henrik
LV since v3.1
Message 7 of 11
(7,854 Views)
Thnaks so much indeed! It's exactely what I want!!! I'm so excited...
Would you please let me know how can I send the whole project? I tried "Save all" but its the same file again.
Petar
Message 8 of 11
(7,845 Views)
You have to save the whole project in a .rar or .zip file. I will be waiting for the code.
Randy @Rscd27@
Message 9 of 11
(7,842 Views)
when I save it as "rar", it can't be attached, I face an error
Message 10 of 11
(7,838 Views)
