Signal Conditioning
Problem with NI-9203
HI, im new to labView Programming and CompactRio. Currrently i used CompactRio to implement my Final Year Project. I need Some advice regarding the connection between Pt100(4-20ma) and NI 9203 Module because i didnt get the correct signal at my labview front panel. What should i do?
(5,912 Views)
Well, let's have a look at your sensor: You wrote Pt100 (4-20mA) , so  you have a Pt100 temperature sensor and while this is a resistive sensor you would need a signal conditioner, that will convert the Ohms into mA that your 9203 can read .  What type (link to datasheet? )
You would also need a powersupply that fit the needs of your conditioner (usually a 24V supply ).
Useful bonus information to the forum:
Temperature range?
Other sensors connected?
 How are they connected to ground?
Greetings from Germany
Henrik
LV since v3.1
(5,891 Views)
