Signal Conditioning
Problems with BNC and chassis termination
Hi All,
forgive me if this is the wrong forum but i assume someone here from a test and measurement background will be able to help.
I am trying to measure leakage current using a source meter and electrometer. The problem i have is that the termination method of my instruments is BNC. The DUT i am measuring is inside a shielded diecast box. In order to make my measurement i am using the chassis and the outer core of the coax cable as the reutn path. However i do not know if this will increase noise within the measurement. I am measuring currents in the Nanoamp region.
Also from a safety point of view i am using high voltage and having the return path going through the diecast box does not sit well with me.
Does anyone have any opinions on this or can advise on a better solution?
Thank You
Andy
Here is a diagram of what i am doing
https://forums.tm.agilent.com/community/download/file.php?id=8518&mode=view: https://forums.tm.agilent.com/community/download/file.php?id=8518&mode=view
(6,180 Views)
qwerty257,
Are you using any National Instruments hardware that you think might be causing some problems here?
Have you tried the setup you described?  Does it give you the desired results?
Sincerely,
Jason Daming
http://www.ni.com/support
(6,153 Views)
Yes i have tried this setup and i do get measurments in approximate range. The trouble is its a leakage current test in the Nanoamp range, ideally the leakage should be as small as possible but i am concerned that the config/setup is causing or adding an error to the  reading.
Also i have concerns over the safet of the setup. The only NI product i am using is labview 8.5 to control the instruments but this post is not really a software issue.
(6,148 Views)
