Signal Conditioning
Quarter bridge configuration 5B38
Hi there,
We seem to have some strain gage reading problems due to some wiring problems and we need to confirm the quarter bridge connections pins (4,3,1) using the 5B38 module. Attach is a picture depicting of how it should be set up. I like some confirmation if this setup is correct? Or is this setup incorrect? Thanks.
Sandy
(3,935 Views)
Sandy
No picture was attached
(3,928 Views)
Opps, here's the attachment I forgot to add.
Sandy
(3,928 Views)
Sandy,
It looks like that wiring is correct.  Just make sure that the completion resistor matches the resistance of the strain guage.  So for example, if you have a 350 ohm strain guage, use a 350 ohm completion resistor.
-Justin
(3,891 Views)
