Signal Conditioning
Read a text file in a FPGA project
I have a FPGA project with a sb-RIO 9606 and I need to manipulate .txt files for encrypt them, so i convert the whole file into an array of 2 dimension. First, i did this vi without the fpga project and it works fine. But when i open it from the project explorer it doenst work.  I did another one starting from the project explorer but its the same. Or if someone knows other way to convert a .txt file to and array ( 2 dimension). Thanks in advance and sorry for my bad english.
(4,549 Views)
It looks like this VI is actually being ran on the RT system, not the FPGA.  In that case, you need to point to a text file that is on the RT itself.  The sbRIO cannot read a file off of your computer.
(4,542 Views)
I want read a file on my pc, then "write" my array as a cluster with the "Open FPGA reference" -> Write
(4,529 Views)
Accepted by topic author Pepe727
Then you need to have 3 applications running: FPGA, RT, Windows/PC.  The PC application reads the file and sends it to the sbRIO, typically via TCP/IP or Network Streams.  The RT on the sbRIO reads the data, processes it, puts the data into a cluster, and then writes to the FPGA.
(4,525 Views)
oh... Can you direct me to a topic that explains that a little more?
(4,508 Views)
Possibly more than you ever wanted: CompactRIO Developer's Guide
(4,501 Views)
