Signal Conditioning
Read to wave form graph
Hi All!
I do not know if I am in the right section, apologies if not.
My question I think is straight forward though, Its just a simple vi I am making that allows me to read a graph after I stop running a vi, I have used a collector which then send the results to a waveform graph.
The issue is that both signals are merged when it comes out of the collector, I need to be able to see the two signal seperately.
I have attached the vi.
Thank you in advance for your help!
(6,309 Views)
Sorry, I forgot to attach the vi!
Also it si two signal I need to see on the resulting waveform graph.
Thanks again
(6,307 Views)
Accepted by topic author Marko1982
If you use the "Index Array" function and index at 0 and 1 you should get both of the signals back out seperately.
All the best,
(6,278 Views)
