Signal Conditioning
Relay operate time of SLSC 12251
What is the relay operate time of SLSC 12251?
I have attached a snap of switch control section from the data sheet, is it same as relay operate time?
Is it possible control all channels simultaneously?
I have requirement to do fault insertion test of 160 no.s of inputs of my UUT. so in that case i have to use 10 no.s of SLSC 12251 cards and can I control all channels in parallel so that I can test 160 signals at the same time.  Is there any other alternative?
Thanks & regards,
Abhiraj
Message 1 of 1
(2,297 Views)
