Signal Conditioning
Replacement Power Supply for SC-2345 (with SCC-PWR02)
Years ago, our group purchased a SC-2345 with the SCC-PWR02 option as part of a full DAQ system.  The power supply for the SC-2345 chassis (described below) recently went bad.  The power supply does not appear to be manufactured by NI.
Question:  Where can I purchase a replacement power supply for a SC-2345 (with SCC-PWR02)?  Did this power supply (even though it doesn't mention NI) likely come with the SCC-2345?
Description:
Name: APP Switching Power Supply
Model: SPA40-3555
Part:    723045-0
Input: Accepts standard computer power cord
Output:  6-pin connection to SC-2345
Pin 1: Ground
Pin 2: Common
Pin 3: +5 V / 3.0A
Pin 4: -15V / -3.0A
Pin 5: Key / Blank
Pin 6: +15V / 1.5 A
Ideas:
The following document describes NI SCC Signal Conditioning systems:
http://www.ni.com/pdf/products/us/4daqsc251-52_266-69_194-96.pdf
Would the power supply come with SCC-PWR02 (part: 183971-02)?  What exactly comes with that part (the card to insert into the SC2345, the transformer, or both)?
(9,002 Views)
Depending on which package you choose from the product website, you are able to purchase different power supply packages. for instance the SC-2345 (777722-03) package includes the AC supply. If you would like to only purchase the power supply, you may be able to do this by contacting your account representative.
(8,963 Views)
Did you get it?
(4,019 Views)
