Signal Conditioning
SC-2345 Increase in Voltage
I am using an SC-2345 to increase create an excitation voltage and then read signals from a pressure transducer. When I was looking at a readout of the transducer's output I had noticed that it was increasing over time. After a few minutes of trying to figure out what was wrong with it I hooked up a multimeter to the SC's output and discovered that the block is putting out more voltage at a rate of about .3mV/minute it is currently at 12.5V and looks like it's slowing but doesn't look like it's going to stop. Anybody know why this is happening or how to fix it?
(6,230 Views)
Suggest you leave it powered up for awhile and check drift over time.  It may be that once it has reached a steady temp, it will settle down.  Does it do this with no load attached?
(6,219 Views)
Yep, power up and give the devices time to settle in temperature. When it comes to calibration we give 2 hours. Well, power up Monday morning and let it run ....
It's a good idea to record the warm up and even longer to get a feeling of stability for your setup.
The reason for this are mostly the temperature drifts of the internal time and voltage references.
Greetings from Germany
Henrik
LV since v3.1
(6,216 Views)
