Signal Conditioning
SC-2345
Hi All
I'm having trouble with a setup using a SC-2345, SCC-SG24 modules, and a USB-6210. I'm trying to get differential outputs from these units but don't seem to have a connection to the -ve signals! Also cant seem to find the signal pinout of the J24 68way connector in the documentation. Beyond J24 the customer has added a 68 to 50way adapter (NI ASSY182420-01) and cable to a breakout board. I'm using J1, J3, and J5 at the moment for 6 strain guage devices.
Thanks Doug
(5,977 Views)
Hi Doug,
Are you connecting the module according to the diagram in this manual https://www.ni.com/docs/en-US/bundle/371073b/resource/371073b.pdf ?
If so then I take it you are seeing no change in input at all when you connect the module?
Kind Regards,
(5,954 Views)
