Signal Conditioning
SCC-2350 Connector Block Adapter Available?
My customer purchased a SCC-2350 chassis (TEDS version) but needs to bring in DIO and CTR lines. The 2350 only support AI and AO and cables directly to the DAQ card. Is there an connector block adapter that lets me connect the SCC chassis using the 68-pin cable, wire in the DIO and CTR signals, and then wire to DAQ card using 68-pin cable?
The old SC-205x series used to allow me to integrate multiple types of signal conditioning. These use the old 50-pin ribbon connectors.
(3,424 Views)
Hi RGSchmidt,
The SC-2350 (as well as the SC-2345) has built in screw terminal banks that allow you to route your DIO and Counter lines to your connecting data acquisition card.  Pages 2-1 and 2-2 in the SC-2345/2350 Carrier Manual discuss the signal connections available (http://www.ni.com/pdf/manuals/371064d.pdf).  Figure 2-1 has the diagram of available pins on the carriers, which map directly to the pin numbers on your connecting DAQ card.  You will want to refer to the pin out diagram for your DAQ card to see which lines are available on these screw terminals.
Thaison V
(3,412 Views)
Thanks.
I found that out yesterday by digging in the manual.
(3,402 Views)
